Patterson Company Posted February 19, 2022 Share Posted February 19, 2022 When using "select similar tool" I am getting this error: "the selected activation options can't be used for this object" This is on all my plans- not a specific one. Quote Link to comment
0 Jeff Prince Posted February 19, 2022 Share Posted February 19, 2022 1 hour ago, Patterson Company said: When using "select similar tool" I am getting this error: "the selected activation options can't be used for this object" This is on all my plans- not a specific one. you need to configure the tool. There are probably some criteria set that is making it impossible for you to select the object… that’s what that message means. 2 Quote Link to comment
0 diskoper Posted September 8, 2022 Share Posted September 8, 2022 Hi. I have the same problem. And I have tried to configure the tool. "I have tried all the options 🤪". Don´t know how to make it work again! Is there a "reset to default" somewhere? Did you solve the problem @Patterson Company? /per Quote Link to comment
0 diskoper Posted September 8, 2022 Share Posted September 8, 2022 (edited) 10 minutes ago, diskoper said: "I have tried all the options 🤪". Guess that was the problem. I tried all the options at once.. release most of the options and just selected "object type" and it works as I want it to do. Was pretty sure I´d already tried that! And, the option "symbol name" doesn´t work on Light Instruments, or stage decks generated by Spotlight. /per Edited September 8, 2022 by diskoper Quote Link to comment
0 Andy Broomell Posted September 17, 2022 Share Posted September 17, 2022 On 9/7/2022 at 11:53 PM, diskoper said: Guess that was the problem. I tried all the options at once Yes, this tool operates by finding other objects that match all of the criteria you've chosen not any. (That is, the criteria are AND not OR). Quote Link to comment
0 mjm Posted September 17, 2022 Share Posted September 17, 2022 On 9/7/2022 at 11:53 PM, diskoper said: And, the option "symbol name" doesn´t work on Light Instruments, or stage decks generated by Spotlight. /per Neither the Stage Decks nor Spotlight Lighting Fixtures are symbols when placed with their respective tools, they're parametric objects, designed to be operated on with the OIP. Quote Link to comment
0 unearthed Posted September 18, 2022 Share Posted September 18, 2022 Sometimes (across several operations including Booleans) I get errors like this and it's because I'm in a rotated view - it should matter but going to normal view solves it. Quote Link to comment
Patterson Company
6 answers to this question
