  • 9
2022 - Class Marker Style - No None
Tom Klaber
We are having an issue with 2022.  Classes seem to have no NONE option for marker styles.  So when we select an item and make all attributes by class - arrows are put all over our couches and toilets.  We then have to manually remove the marker in the OIP.
What am I missing?  How can we set NONE to the marker style of a class?
image.thumb.png.fcefacf965456ad997f07bbe6f92baf8.pngimage.png.d348ae4a9d3b70e73964d141722816a4.png
Edited by Tom Klaber
  • Like 4
20 answers to this question
This doesn't seem right. When I select the Make All Attributes By Class command in 2022, it only uses the class markers where markers already exist. It's not adding markers to all geometry like I'm seeing in your screengrab, so I'm not sure what's happening.
Are you on the current SP? Does this happen in a blank file too?
I'm also having this issue. Yes, you can work around it by creating custom arrowheads, or setting classes to not use class defaults. But frankly, this is a boneheaded bug that should never have gotten passed QC. Fix this people
  • Like 3
How about some work arounds.  Below are two scripts. The first sets the markers of the Active Class to a Custom style using the line thickness and an arrowhead offer length and zero angle.  The second script does the same but for every class in the document.
Run these from a script palette or make Plug-In Menu commands out of them and add them to your workspace.   For information on how to do either of these, see this pinned post:
Procedure NoMarker;
{April 19, 2022}
{©2022 Patrick Stanford pat@coviana.com}
{Licensed under the GNU Lesser General Public License}
{No Warranty Expressed of Implied. Use at your own risk.}
{Sets custom markers of zero length and angle to the active class}
VAR
	S1		:String;
	B1		:Boolean;
BEGIN
	S1:=ActiveClass;
	B1:=SetClassBeginningMarker(S1, 0, 0, 0, 0, 0,0);
	B1:=SetClassEndMarker(S1, 0, 0, 0, 0, 0,0);
End;
Run(NoMarker);
Procedure NoMarkerAllClasses;
{April 19, 2022}
{Sets custom markers of zero length and angle to all classes}
VAR
	S1		:String;
	B1		:Boolean;
	L1		:LongInt;
BEGIN
	For L1:= 1 to ClassNum DO
		Begin
			S1:=ClassList(L1);
		End;
End;
Run(NoMarkerAllClasses);
Interesting that no-one from Vectorworks has entered this discussion.  It is very telling that VW are always quick to blame the users saying that we are not using the program as it is intended and that items are 'working as designed' and that there is a very good reason why the software is now operating in the way it does.
Can someone from VW please step up in and tell us why you have removed the 'none' marker setting ??
Also, I am not a programmer - why should I have to use a code to fix something which was not broken in the first place.
This one is almost up there with the debacle of the Title Block borders a few years back.
Or do we roll back to SP1 - as everyone knows that SP2 didn't actually work and that all bugs were meant to be sorted in SP3???
I don't think there was ever a "none" setting in the Class Marker settings. The class settings only define what the markers look like if/when an object is set to use by-class markers in the Attributes Palette. The class settings don't determine IF markers are used; that's the job of the Attributes Palette.  If you deselect everything, make sure the Attributes Palette has markers set to "None," and then draw objects on that class, you shouldn't be getting any markers. Markers are only drawn if markers are enabled prior in the Attributes Palette prior to drawing something, or are manually turned on for an object.
That being said, I wouldn't be surprised if the bug people are experiencing is more along the lines of the bug where Vectorworks adds markers to objects when the Attributes Palette Default is set to have markers on (despite the object itself being set to not have markers). As an example, in the current build, markers get added to Auto-Hybrids upon regeneration whenever the Attributes Palette is set to have markers on. The 2D geometry of an Auto-Hybrid should never have markers. This is a bug which has popped up before and has been fixed but has recently returned [VB-184415]. Perhaps this same issue is affecting other scenarios too hence this thread.
Again, I don't think this has anything to do with class settings. But please correct me if I'm wrong.
Edited by Andy Broomell
I think you might be right @Andy Broomell
In VW2022SP3, when you use the All Attributes by Class option in the Attributes Palette, the Markers are not set to By Class. So individual objects can be set to use markers or not.
If you truly want ALL attributes to be By Class but not have markers show you will have to use the zero size marker options discussed above.
I think in earlier versions of VW2022 the actual bug was that the markers were set to By Class when using the All Attributes By Class option.
I was getting arrow markers turning up on the leaders on my Data Tags in a VW2022 file recently. I couldn't figure out why it was happening + couldn't seem to control it but thankfully hasn't happened since...
496087021_Screenshot2022-04-21at21_23_38.thumb.png.ccf12cbe10ca2a2fa8f51d0abbbbccf8.png
I think you hit the nail on the head.
I just tested out the original release and what you describe indeed happens. Whereas in the current build, choosing "Make All Attributes By Class" [with nothing selected] sets the markers to None, which is as it should be.
If an object is selected which ALREADY has markers on, the enabled markers will be switched to the Class style when choosing "Make All Attributes By Class."
I seem to remember that arrows used to be simpler, and that the interface allowed you to add or remove them with a single click, rather than having to pull down and select.  I don't know when this changed, and maybe I was not using By Class much at the time.
It changed with the revised Attributes Palette which debuted in 2022. I remember someone saying the change was in order to make the interface consistent with other settings elsewhere, where "None" is the first option in a dropdown. I suppose it does clean up the look of the Attributes Palette a bit, but I too miss the ability to turn off markers with a single click rather than a long scroll list.
This just gave me an idea though... If they want to keep the GUI as-is, they should add a hotkey shortcut to quickly remove a marker, such as holding Cmd or Opt while clicking on the marker dropdown, in which case the marker would simply be removed with one click and the dropdown wouldn't pop up.
