Theo D Posted February 17, 2022 Share Posted February 17, 2022 (edited) Hi all ! Little practical question, do you know how is it possible to use the wall projection tool on a roof profile. I'm not talking about skylight or dormer but about the wall projection tool (in my case to show the modulations and variations of steel sheet that make up the roof on the 3D). Thanks you for your help ! Edited February 17, 2022 by Theo D Quote Link to comment
Tom W. Posted February 17, 2022 Share Posted February 17, 2022 Aha thanks for the edit! No you can't use Wall Projection command on roofs. And you can't use a Wall Hole Component symbol either to clip the surface. But you could perhaps do it with Create Surface Array command. Or if it were possible to make the roof using a Slab instead that would give you some options Quote Link to comment
