sfatelier Posted August 18, 2005 Share Posted August 18, 2005 I currently have a problem plotting only one sheet in a drawing file. It shows the full sheet on the screen but when it plots, only a quarter plots before it spits the sheet out. I've tried creating another layer with the same information but it still does the same thing. Three of the viewports have scanned images in them. Could this be the source of the problem (memory issues?)? I'm working with Version 11 and my plotter is an HP 11oplus. Thanks for your help! [ 08-18-2005, 07:59 PM: Message edited by: sfatelier ] Quote Link to comment
islandmon Posted August 19, 2005 Share Posted August 19, 2005 Check your ViewPort >Layer>sheet>page set up and print area. Quote Link to comment
sfatelier Posted August 26, 2005 Author Share Posted August 26, 2005 Thanks, I'll try to see if I can figure it out that way! Quote Link to comment
sfatelier Posted September 8, 2005 Author Share Posted September 8, 2005 Hello, I've done all that but it still behaves the same way. Could it be a memory problem for the sheet? Quote Link to comment
Kevin Posted September 9, 2005 Share Posted September 9, 2005 I had that happen under OS9 when printing to a desktop printer. It seems that the image was too memory intensive. I would experiment to see what you can find out. Try printing to PDF. Try reducing the resolution of the images. You should be able to determine if it is memory related or otherwise through this kind of troubleshooting experimentation. Quote Link to comment
