MaltbyDesign Posted February 13 Share Posted February 13 (edited) I often use the Create Roof tool to quickly create shed roofs, done by converting 3 of the 4 sides to gable ends and the low side of the roof remaining an eave. Inserting a fascia will only add a fascia board to roof edges that remain an eave. Any edges of the roof that have been converted to a gable end will not receive a fascia board. This seem like the most basic of flaws in the software, particularly when trying to quickly model a design idea. Am I missing something? I don't think this should be a difficult task. Edited February 13 by MaltbyDesign Quote Link to comment
Vectorworks, Inc Employee Wes Gardner Posted February 15 Vectorworks, Inc Employee Share Posted February 15 @MaltbyDesign yes, the Roof tool needs some love...much of the fascia/eave just doesn't work the way it should Wes 1 Quote Link to comment
techdef Posted February 16 Share Posted February 16 My new trick has been a "fascia" Wall, ie: a wall that's 1x14 with a single component set to something like Component_Trim_Paint. Draw that wall around the perimeter of your roof. Use the wall height handles to snap to the actual roof peaks & ridges. Its super easy and gratifying compared to the default tools. 4 Quote Link to comment
DuncanR Posted February 16 Share Posted February 16 You could also do your fascias as an extrude along a path. That way you can have a standard library of profiles for use. We use this approach for almost all fascia/soffit arrangements as the built in tool just doesn't do what we want it to. 1 Quote Link to comment
MaltbyDesign Posted February 19 Author Share Posted February 19 Thanks for the alternate approaches. I just wish that the built in tools worked as expected without having to find workarounds. Quote Link to comment
MaltbyDesign Posted February 19 Author Share Posted February 19 @techdefwould you mind sharing a screenshot of your Insertion Options in the edit wall style dialogue box? I've got the wall as fascia part but can't get the wall to follow the top and bottom of the sloped roof. Thanks in advance. Quote Link to comment
techdef Posted February 22 Share Posted February 22 @MaltbyDesign, sorry if that wasnt totally clear. Use the Reshape tool to move the top & bottom up/down after insertion. In a 3d view you can grab handles at the ends of the walls at top & bottom to adjust them / snap to roof or (whatever) object. 1 Quote Link to comment
MaltbyDesign Posted February 25 Author Share Posted February 25 @techdefThanks for the clarification. I'll give that a try. I was trying to get the 'fascia' wall to follow the roof but that wasn't working. Quote Link to comment
