elc Posted February 11 Share Posted February 11 Hello all, since I am starting with the documentation of a project with multiple rooms, I wanted to ask, if there are any best practice tips on how to set up my file(s)? Lets say I have a building with 40 rooms for "end users" and 5 rooms with technical equipment spread out over the entire building. Usually (e.g. in AutoCAD) I could have all rooms in one model space and just create layout pages showing the individual rooms. And blocks for all devices being used. How would I do that in ConnectCAD? a. have one Schematic design layer with all room setups? b. have separate schematic design layers for the buildings floors? c. have seperate design layers for each individual room? Or would I use separate files, e.g. one for each floor of the building? Thanks for any hints (direct or via a resource link) Best, George 1 Quote Link to comment
Mark Aceto Posted May 25 Share Posted May 25 @elcwhere did you land with this? I'm going through the same thing with a 2-story install. Assuming I'll just duplicate the schematic view, add corresponding sheet layers as necessary, and control vis with layers and classes. Quote Link to comment
elc Posted May 26 Author Share Posted May 26 hi @Mark Aceto, that's a good questions, that can't be put into two sentences. what I've learned so far though, is that it greatly depends on what your final outcome has to look like. In my case I need A3 sheets for each room. And I don't seperate systems (audio, video, control, IT,... and so on). Everything is in the same drawing. Also I am not using Spotlight. I am really only here for ConnectCAD. At least for now. But the file is huge (40MB) already and tools are starting to get slow. So I am not sure, if I really want to explore all the 2D and 3D options VW gives us. 😉 But in a nutshell: started out with one layer per room and am (in a second project) trying the one design layer per floor approach due to technical and workflow issues. A bit more details if you are interested: Since I haven't heard back on the forum, I just started with one design layer per room. While layers/rooms with a lot of equipment have to be spread out so they can be printed on seperate layout sheets. (might require arrow connections for in-room equipment). Main reason for this was that I could assign the room name to the layer and reference the layer in my said arrow connections (e.g. "--> Layer/RoomName - Device Name - Port Name"). But the workflow of moving arrow connections between layers is not as fluent as one might hope. And I had issues with inter-layer cabling (lost connections with no solution yet). Which is a pain when you try to move large amounts of devices with a box select. But it seems to happen mostly(?) to EXT devices. I don't know. I just try to select the devices without the arrow connections. But I am getting off topic. 😉 Because of the above unsure situation and the fact that a few tools only work on the same layer I wanted to try to keep the amount of layers for the schematics to a minimum and only have one layer per floor. Let's see how that goes. 🙂 Again a pretty long post, sorry. But it is still just a fraction of the issues questions I would still have. 😄 Still in the trying-to-wrap-my-head-around-VW phase though. Hope this helps anyway. Would be intersting what you decided on and what output you have to generate regarding paper size and system separation? (We were also thinking about just going with A0 for larger rooms instead of multiple sheets and arrow connections) Best, George 1 Quote Link to comment
Mark Aceto Posted May 27 Share Posted May 27 (edited) @elcthanks for the quick reply! I ran into a lot of the same considerations and caveats (as my sheet layer from 11x17 to 24x36 to 36x48), so I think I'll keep everything on the same Schematic design layer, and then use viewport cropping to break out to multiple sheet layers. I also will have to layer in multiple depts / systems, so that will get interesting... @Conrad Preendoes it make sense to use rooms as floors in a 2-story building? In other words, nest multiple rooms inside of a (floor) room? Screenshot below for clarification. Or should the room organization be "flattened" like: Floor 1 - Room A Floor 1 - Room B Floor 1 - Room C Floor 2 - Room A Floor 2 - Room B Floor 2 - Room C (Apologies if this is answered in the Help documentation.) Edited May 27 by Mark Aceto 1 Quote Link to comment
elc Posted May 28 Author Share Posted May 28 Hi @Mark Aceto depending on the amount of devices this sounds like a good approach. Another questions: is there a function for floors? Or are you just talking about the design layers that you use as floors? In your image you are using the room function on the schematic layer, right? As far as I know, this does not work with the room data attached to devices (schematic layer) only with equipment (in the rack elevation layer)? Or how did you set this up? Best, George Quote Link to comment
