Fabio Martucci Posted February 9, 2022 Share Posted February 9, 2022 Hi All! I'm working on a project in which I am creating a 3D Model from a DWG of a Pavillion of the FAIR of Milano. At the moment I am blocked because I can't find the right way to reproduce the Window/Door of that used the Door Tool. I have tried starting from "Barn Door 2 Leaf Bi-Parting w Box Rail" and modified it without a good result. Have someone an idea as to how can I realize it, starting from a parametric object? I attached a picture of the real door! Thanks! Quote Link to comment
Pat Stanford Posted February 9, 2022 Share Posted February 9, 2022 Model the door the way you want it and make it a Symbol. Put a Door in the wall and use the Use Symbol Geometry to pull what you have modeled. That will be much easier than fighting with the Door object to try and make something more complicated than it was designed to do. Quote Link to comment
TomKen Posted February 14, 2022 Share Posted February 14, 2022 You can do it with the curtain wall tool and a curtain wall doors. Door.vwx Quote Link to comment
zoomer Posted February 14, 2022 Share Posted February 14, 2022 Do VW US Curtain Wall inserted Doors still have Sashes only - but no Jambs ? Quote Link to comment
