filip Posted February 8, 2022 Share Posted February 8, 2022 Dear vw users, I like t make the window id tag smaller in my drawings, but I can't find the path for that symbol. Has anyone a idea? best regards Filip Bosscher Quote Link to comment
shorter Posted February 8, 2022 Share Posted February 8, 2022 Are you using the Data Tag? Quote Link to comment
filip Posted February 9, 2022 Author Share Posted February 9, 2022 I don't think so, it's called ID-tag in the windowtoolbox. see screenshot of a fragment op a floorplan, and you see that those wind id parkings are to big; I wan't them to be half that size. best regards Filip Quote Link to comment
TomKen Posted February 9, 2022 Share Posted February 9, 2022 Simply select the window and set the text size from the Menu Bar drop down Text>Size Quote Link to comment
shorter Posted February 9, 2022 Share Posted February 9, 2022 Use one of the data tags with incremental numbering… Quote Link to comment
filip Posted February 10, 2022 Author Share Posted February 10, 2022 thanks....that simple and I couldn't figure it out best regards Filip Bosscher Quote Link to comment
Guest Wes Gardner Posted February 15, 2022 Share Posted February 15, 2022 As a general "best practices", I'd recommend using Data Tags and tag your objects on your sheet layers in your viewports...this way they will scale properly if you need to make an Enlarged Stair Plan or Enlarged Toilet Room Plan or similar. You can also create a tag specific to your office standard and save it in the Resource Manager where you can then share it/export it/ copy and paste it to another file. Wes Quote Link to comment
filip Posted February 16, 2022 Author Share Posted February 16, 2022 Dear Wes, is there a tutorial for the use of Data Tags, I can't find a Data Tag somewhere in the menus. Filip Quote Link to comment
Guest Wes Gardner Posted February 16, 2022 Share Posted February 16, 2022 @filip you might want to check on Vectorworks University - here's a link to three or four tutorials.. https://university.vectorworks.net/course/index.php?mycourses=0&tagfilter[category]=0&tagfilter[type]=0&tagfilter[difficulty]=0&categorysort=default&mycourses=&search=data+tag&langfilter[]=0 Wes Quote Link to comment
