Script for walls
Hello everyone, I just created a script with the multi tool where it selects the walls tool and at the same time puts the wall on the correct class and level. How can I add to the script so that I can set the right style for the Walls tool?
Procedure CustTool;
VAR
Result:BOOLEAN;
BEGIN
PushAttrs;
Result := DeleteAllComponents(nil);
Result := InsertNewComponentN(nil, 1, 15, -366, 14, 2, 2, 2);
Result := SetComponentName(nil, 1, 'Putz');
Result := SetComponentClass(nil, 1, 13);
Result := SetComponentFillColors(nil, 1, 257, 256);
Result := SetComponentPenColors(nil, 1, 257, 256, 257, 256);
Result := SetComponentUseFillClassAttr(nil, 1, FALSE);
Result := SetComponentUsePenClassAttr(nil, 1, TRUE, TRUE);
Result := InsertNewComponentN(nil, 2, 200, -130, 14, 14, 2, 2);
Result := SetComponentName(nil, 2, 'Beton');
Result := SetComponentClass(nil, 2, 213);
Result := SetComponentFillColors(nil, 2, 257, 256);
Result := SetComponentPenColors(nil, 2, 257, 256, 257, 256);
Result := SetComponentUseFillClassAttr(nil, 2, FALSE);
Result := SetComponentUsePenClassAttr(nil, 2, TRUE, TRUE);
Result := InsertNewComponentN(nil, 3, 15, -366, 14, 2, 2, 2);
Result := SetComponentName(nil, 3, 'Putz');
Result := SetComponentClass(nil, 3, 13);
Result := SetComponentFillColors(nil, 3, 257, 256);
Result := SetComponentPenColors(nil, 3, 257, 256, 257, 256);
Result := SetComponentUseFillClassAttr(nil, 3, FALSE);
Result := SetComponentUsePenClassAttr(nil, 3, TRUE, TRUE);
PenSize(14);
PenPatN(2);
SetZVals(0", 0);
NameClass(' ▲ 00 Standard - Mauerwerk');
Layer('03_Waende');
SetPref( 3, True );
SetPref( 1013, True );
SetPref( 1014, False );
SetPref( 1015, False );
SetPrefReal( 78, 1.000000 );
SetPrefReal( 79, 1.000000 );
SetPrefReal( 1019, 1000.000000 );
SetPrefReal( 1020, 1000.000000 );
SetPrefReal( 1021, 0.000000 );
SetPrefReal( 1022, 2540.000000 );
SetPrefReal( 1023, 2540.000000 );
SetPrefReal( 1024, 25400.000000 );
SetPrefReal( 1025, 25400.000000 );
SetPrefReal( 1026, 0.000000 );
SetPref( 35, False );
SetPref( 36, False );
SetPref( 1027, True );
SetPref( 1028, True );
SetPref( 1029, True );
SetPref( 1030, True );
SetPref( 1031, True );
SetPref( 1032, True );
SetPref( 1033, True );
SetPref( 1067, True );
SetPrefString( 1034, '45.000000;30.000000' );
SetPref( 1035, True );
SetPref( 1036, True );
SetPrefReal( 53, 0.000000 );
SetPref( 1037, True );
SetPref( 1038, True );
SetPref( 1039, True );
SetPrefReal( 1040, 0.100000 );
SetPref( 4, False );
SetPrefReal( 1041, 2.000000 );
SetPref( 1042, False );
SetPrefReal( 1043, 0.000000 );
SetPref( 1044, False );
SetPrefReal( 1045, 0.500000 );
SetPref( 1046, True );
SetPref( 1047, False );
SetPrefReal( 1048, 0.000000 );
SetPref( 1049, True );
SetPref( 1050, True );
SetPrefReal( 1051, 0.250000 );
SetPrefReal( 1052, 0.000000 );
SetPref( 1053, False );
SetConstrain('qswdf');
CallTool(-208);
PopAttrs;
END;
Run(CustTool);
I just read your script more closely.  You are manually setting all of the components of the wall. You don't need or want any of that if you are going to use styles.
You should be able to replace all the lines that start with Result with the single SetWallPrefStyle line.
You can probably get rid of almost all of the SetPref section also. Do you really need to set the snapping preferences and grid preferences as part of the tool?
SetSlabPreferencesStyle(Name2Index('Slab Style Name'));
SetRoofPrefStyle(Name2Index('Roof Style Name'));
Thanks for the help! Now the thing works. Attached are the scripts for the community
Procedure WallTool;
VAR
Result:BOOLEAN;
BEGIN
SetTool(-208);
Result:=SetWallPrefStyle('FR_Ziegel__200');
NameClass(' ❒ 06 Bauteile - Wände');
Layer('03_Waende');
SetPref(44,TRUE);
END;
Run(WallTool);
Procedure SlabTool;
VAR
Result:BOOLEAN;
BEGIN
SetTool(-248);
SetSlabPreferencesStyle(Name2Index('FR_Bodenplatte-Parkett_Ei'));
NameClass(' ❒ 06 Bauteile - Bodenplatte');
Layer('03_Bodenplatte_1');
SetPref(44,TRUE);
END;
Run(SlabTool);
