Dylan Posted February 7, 2022 Share Posted February 7, 2022 Good afternoon folks, I've been banging my head agains the screen for 2 hours now trying to cut out a basement from a site model. I've got a 3D polygon in the outline of the basement footprint set to the proper elevation. If I convert it to a Pad site modifier, the ground slopes into it. I need the edges of the cut to be vertical. I've played around with a Grade Limit 3D poly to the same shape as the basement footprint but it's not really doing anything. Does anyone have a method of cutting a basement out of a site model? This file is in VW 2021. Thanks folks. - Dylan Quote Link to comment
Pat Stanford Posted February 7, 2022 Share Posted February 7, 2022 The Site Model does not handle vertical cuts. Make the pad the size you need and then make the Grade Limit to be 1mm (or even 0.01mm) larger in every direction and you will get a close simulation of what you are trying to do. Or do it the other way and make the Grade limit the exact size so you have the surface shape correct and then make the pad slightly smaller. HTH Quote Link to comment
Dylan Posted February 7, 2022 Author Share Posted February 7, 2022 Oh Pat! Thank you! The 1mm works beautifully. 1 Quote Link to comment
Jeff Prince Posted February 8, 2022 Share Posted February 8, 2022 Or you can use the Pad with Retaining Edge. It’s pretty handy once you get the hang of it. Reshape tool allows you to set the top of your basement nicely, especially walkout basements or split level ones on hillsides where you want to maintain a relationship with the existing grade. Basements on flatland are a cakewalk with this tool. 3 Quote Link to comment
E|FA Posted February 8, 2022 Share Posted February 8, 2022 I think the Pad with Retaining Edge is the preferred method to learn, because you might need the Grade Limit to control a larger area. It is a confusing tool to use at first. 3 Quote Link to comment
Dylan Posted March 3, 2022 Author Share Posted March 3, 2022 Thanks again folks, I did play some more with the Pad with Retaining Edge and it also works great. It took a while to figure out how to use it.... Now that I understand how the tool works, it seems the better tool for the job I needed rather than using the Grade Limit modifier. - Dylan Quote Link to comment
