Is it possible to call a VS routine (or menu command) from a marionette object?
Hello,
some time ago I made a Vectorscript Menu command that computes the current date and writes to a database record.
Now I'd like to implement this in a Marionette Object. Whenever I click a button in the OIP of the Marionette Object it should call the Vectorscript.
Is this or something similar possible and how do I do it?
Thanks for help
VvierA
I think you will be better off reimplementing the command in Marionette rather than trying to call a menu command from the Marionette object.
Since there are no date functions in Marionette you could either implement a node that does all the calculations by converting the script to Python, or you could possibly write a node that implements the Vectorscript DoMenuTextByName command to run the existing script you have.
I would recommend the first if you are going to the trouble to learn how to make/edit nodes it will make things more stable.
  • 1 month later...
