ron Posted July 18, 2005 Share Posted July 18, 2005 Is there a way to offset the sash location in a window? I have a very thick wall which I inserted a window into, adjusted it to look the way I want but want to push the sash/glazing off center of the wall. Thanks Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 18, 2005 Vectorworks, Inc Employee Share Posted July 18, 2005 Use the (aptly named) "Offset in Wall" parameter under Jamb and Trim Settings. Quote Link to comment
ron Posted July 18, 2005 Author Share Posted July 18, 2005 Yes, but that offsets the whole window, not just the sash. I tried before to make that work (adjusting the various sill depths etc) but the edges of the wall/window cut still extend past the wall. Is there a way to offset and keep the wall lines in their proper place? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 18, 2005 Vectorworks, Inc Employee Share Posted July 18, 2005 Are you using the "Use Wall Thickness" option? If so, turn it off and set the jamb depth. Quote Link to comment
ron Posted July 18, 2005 Author Share Posted July 18, 2005 That was the trick. Thanks for your help. Quote Link to comment
