danm01 Posted February 3, 2022 Share Posted February 3, 2022 Hello all, I struggled with this a bit, so I figured I'd share in hopes of saving someone else some pain and anguish. The key learning is that the result of vs.GetObjecTags(class_handle) is a 2-element tuple that contains TRUE in index 0 and either None or a nested tuple with all attached tags in index 1. Once I figured that out it was easy to work with the list. I have not experimented, but I imagine Layer Tags work the same way. Example below creates a worksheet with a list of Class Tags: import vs classes_total = vs.ClassNum() taglist = [] # make a list of tag names, skipping classes without a tag for x in range(classes_total): ClassName = vs.ClassList(x + 1) hClass = vs.GetObject(ClassName) tagTuple = vs.GetObjectTags(hClass) if tagTuple[1] == None: pass #skip classes with no tag else: tagArray = tagTuple[1] for i in range(len(tagArray)): tag = tagArray[i] if tag in taglist: pass else: taglist.append(tag) # check for the Class Tag List worksheet. If it doesn't exist, create it. ws_handle = vs.GetObject("Class Tag List") #if no worksheet found, create it if vs.GetTypeN(ws_handle) != 18: ws_handle = vs.CreateWS("Class Tag List",len(taglist)+1,1) vs.SetWSCellFormulaN(ws_handle, 1, 1, 1, 1, "Class Tags") vs.SetWSCellTextFormat(ws_handle,1,1,1,1,0,0,1) #make the header bold #if the worksheet exists, easist way to handle is delete everything except the header and start from scratch else: rowcount = vs.GetWSRowColumnCount(ws_handle) vs.DeleteWSRows(ws_handle, 2, rowcount[0]-1) vs.InsertWSRows(ws_handle, 2, len(taglist)+1) vs.DeleteWSRows(ws_handle, len(taglist)+1, 1) # add elements from the tag list to the worksheet. for i in range(len(taglist)): vs.SetWSCellFormulaN(ws_handle, i+2, 1, i+2, 1, taglist[i]) vs.SetWSCellTextFormat(ws_handle,i+2,1,i+2,1,0,0,0) #make the content rows regular text vs.ShowWS(ws_handle,True) This example shows or hides classes based on tag value: import vs TagStr = 'Audio' ShowMe = 1 def ViewByTag(TagName,ShowHide): classes_total = vs.ClassNum() for x in range(classes_total): ClassName = vs.ClassList(x + 1) hClass = vs.GetObject(ClassName) tagTuple = vs.GetObjectTags(hClass) if tagTuple[1] == None: pass else: tagArray = tagTuple[1] if TagName in str(tagArray): if ShowHide == 0: vs.HideClass(ClassName) else: vs.ShowClass(ClassName) ViewByTag(TagStr,ShowMe) Enjoy! Real Python coders, please feel free to weigh in if you see an issue. Dan 1 Quote Link to comment
