BillW Posted February 3, 2022 Share Posted February 3, 2022 Has anyone managed to get procedure "ConsolidatePlanar(obj1,obj2) : BOOLEAN" to work. In the attached VW2020 file I have a polygon (named "testpoly") which is rotated in 3D by 45degrees around the X axis. In the script palette I have a script "test consolidateplanar" which when run shows new/old objects are planar but ConsolidatePlanar fails. The new locus is in the correct X/Y position but not aligned with the rotated polygon ie Z direction is vertical. I can do what I want with vector routines but thought ConsolidatePlanar might be easier. I tried reseting the new object, bounding box or 3DOrientation with now luck. As an aside, I noted when I used an oval it wasn't in the correct position when viewed from Top/Plan. Anyone had any luck?? procedure test; Var objH : HANDLE; refID :LONGINT; x1,y1,x2,y2,z2 : REAL; consolidated,planar1,planar2,btest : BOOLEAN; begin objH := getobject('testpoly'); dselectall; setselect(objH); if objH <> NIL then begin refID := GetPlanarRef(objH); GetPolyPt(objH,1,x1,y1); btest := PlanarPtTo3DModelPt(refID,x1,y1,x2,y2,z2); locus(x2,y2); {OvalN(x2,y2, 1, 0, 50, 50);} consolidated := ConsolidatePlanar(objH,LNewobj); {align new object with existing object??} planar1 := getObjectVariableBoolean(objH,1161); planar2 := getObjectVariableBoolean(LNewobj,1161); message(planar1,' ',planar2,' consolidated ',consolidated); end; end; run(test); consolidate planar test VW2020.vwx Quote Link to comment
