Abigail.Landscapes Posted January 31, 2022 Share Posted January 31, 2022 Can anyone tell me how to update viewports on my sheet layers? I made a change to the design layer after creating a viewport and thought the viewport would automatically update. I right clicked on the viewport and selected "Edit Design Layer" and "Update", nothing happened. Do I need to make a new Viewport to replace the existing viewport any time I make a change or turn something on/off? Thanks for your advice! Quote Link to comment
Boh Posted January 31, 2022 Share Posted January 31, 2022 Hi Abigail. 8 minutes ago, Abigail.Landscapes said: Do I need to make a new Viewport to replace the existing viewport any time I make a change or turn something on/off? No you don't have to do this. Viewports in Top/Plan view update automatically. Any other viewports you need to update yourself. With a vp selected there is an "Update" button in the OIP (which will be red if the VP is out of date). You can also right clicking on a vp and select "Update" from the context menu. The view menu also has a "Update All Viewports" command. 1 Quote Link to comment
Abigail.Landscapes Posted February 9, 2022 Author Share Posted February 9, 2022 Thank you for your answer! I also dug around more information and found that the class was off in the Viewport and I had to turn it on 1 Quote Link to comment
