Christiaan Posted January 28, 2022 Share Posted January 28, 2022 My head doesn't compute the criteria interface properly. My criteria needs to be all symbols called Support_Plates on layer 1-Slab C1 and 1-Slab C2. Why does this: Turn into this? Quote Link to comment
0 Pat Stanford Posted January 28, 2022 Share Posted January 28, 2022 Because you only have a single item in the set you don't need a set and it eliminates it. Criteria that use the same criteria type (In your case Layer) are automatically OR'd together and then AND'd against the other criteria. So what both of the above options compress to is ((Layer is C1) OR (Layer is C2)) AND (Symbol is 'Support Plate') HTH. Quote Link to comment
Christiaan
Why does this:
Turn into this?
1 answer to this question
