Dundee901 Posted January 24, 2022 Share Posted January 24, 2022 I'd appreciate some guidance - a second opinion really - on scaling imported objects. A client has sent me a PDF of a garden plan (probably hand drawn, it's a few years old) and asked me to use Vectorworks to work out areas of lawn. There is no annotation, no scale bar and no other measurements shown on the plan - except that it has a nominal scale of 1:200. I create a new file and import the PDF. I cannot use the Modify > Scale Objects command to correctly scale the PDF object as I don't know any distances. However, before importing the PDF, I changed the Layer Scale to 1:200 in the Document Setup. Then I imported the PDF. Can I now accurately measure straight off the plan, without any further scaling? This seems a very obvious question but I just wanted to check! Following import, I have used the tape measure tool to measure some objects on the drawing whose size I can guess (e.g. a doorway, step treads) and I get sensible/believable results but that's not very scientific! Thanks Quote Link to comment
Pat Stanford Posted January 24, 2022 Share Posted January 24, 2022 NO!!!! It is very unlikely that the scale came in correctly. You are going to have to get a real world dimension of something on the plan that you can then measure and scale the drawing to. 1 Quote Link to comment
Dundee901 Posted January 25, 2022 Author Share Posted January 25, 2022 Thank you for making that very clear, Pat! Appreciated. Quote Link to comment
