gimill Posted June 9, 2005 Share Posted June 9, 2005 hello, i'm dealing with a building that has virually no 90 degree angles. i would appreciate some assistance in creating wall endings that are not angular to the wall direction. For instance, if i want to join a glass wall in between two solid walls, you can imagine i don't want beveled edges, but with the skewe shapes i'm dealing with, i seem to have to choose between beveled edges, or 90 degree angle capped walles with a glass wall in between. neither ar satisfying. ofcourse i can fake the caps, then i can almost start drawing the oldfashioned way.. can someone help me with this? thanks Quote Link to comment
Delmer Posted June 9, 2005 Share Posted June 9, 2005 Use the Split Tool in line trim mode to cut the wall at the angle you want then add cap. Quote Link to comment
gimill Posted June 10, 2005 Author Share Posted June 10, 2005 thanks, that helped! Quote Link to comment
islandmon Posted June 10, 2005 Share Posted June 10, 2005 You may also want to limit the number of linked walls by groupings of two. reason is that when all your walls are grouped they act as a single unit and a change to one wall length & intersection may produce strange results in the others. Quote Link to comment
