I'm trying to create a new symbol with an attached record. I have done this before, and just tested creating and using it in 2020, which works fine. In 2022 I can't make it work.
I have simplified everything to try to find the problem, but no luck. The file below has a circle which I have turned into a symbol. I created a new record from an existing one and modified it - I thought this might be the problem, so I pulled an existing data record in without modifying it. There should be a text in the middle of the circle that displays the "weight" parameter of the record - I used the link text to record tool to make this. Opening the Edit 2D symbol shows the text, but inserted symbols do not show the text, nor a placeholder. They do have a record attached, which seems to work as expected in the OIP, with the exception of the text not showing up on the symbol.
I suspect some bug, because I just did the exact same sequence of actions in 2020 and it works fine.
Jake124
Any help please? TIA
https://1drv.ms/u/s!Av4RU7VvWoY12UUSXVlBzZj-dhr1
6 answers to this question
