mattryan Posted January 18 Share Posted January 18 Hi I have a file with some window issues, There are several windows that appear in plan but when switching to 3d and using the shaded render they disappear It's as if they are not inserted in the wall properly. However I cannot move them to pull them off the wall, its as if they are frozen. I have turned on all the classes thinking that this might be a class issue but it has no impact. There are other windows in the file are visible and functioning the way they are supposed to and in the same wall type as the windows that are disappearing. When I try to insert a new window in the wall that is causing me issues, all of the previous windows disappear. Does anyone have any idea? Thank you Quote Link to comment
Vectorworks, Inc Employee Wes Gardner Posted January 19 Vectorworks, Inc Employee Share Posted January 19 Hi Matt, @mattryan can you post a wall and window that are having the issue? Wes Quote Link to comment
mattryan Posted January 19 Author Share Posted January 19 Hi Wes Do you mean a Vectorworks file? Thanks for looking at this Matt Quote Link to comment
Vectorworks, Inc Employee Wes Gardner Posted January 19 Vectorworks, Inc Employee Share Posted January 19 @mattryan yup...I don't need the entire project just a sample wall and window that are having the problem Wes Quote Link to comment
P Retondo Posted January 19 Share Posted January 19 (edited) Look at the z height of the window that isn't showing up. Sometimes it can be above or below where you intend it to be, entirely outside the wall. Also, as I look at your wireframe vs. rendered wall, it could also be that you have two walls superimposed (easy to do). The windows may be in one and not in the other. Edited January 19 by P Retondo Quote Link to comment
Hans-Olav Posted January 19 Share Posted January 19 Hi @mattryan Is it an older project opened in 2022? If so, I have learned that sometimes it helps to move the window by zero to make the plugin regenerate and the opening appears again Quote Link to comment
mattryan Posted January 19 Author Share Posted January 19 Thanks Pete and Hans, I checked to see if there was another superimposed wall but there isn't. Also yes the file was originally created in 2021 so I tried the zero move but that unfortunately didn't work. Good tips, thanks! Quote Link to comment
Vectorworks, Inc Employee Wes Gardner Posted January 19 Vectorworks, Inc Employee Share Posted January 19 @mattryan honestly, I have no clue what's up with those windows...probably not what you wanted to hear...I created some new ones and they seem to work just fine...it's odd that you can't move yours or edit them??? It might be worth getting a hold of Tech Support and see if they can figure it out. In the mean time, I think I'd create new windows and move forward with your project Wes Quote Link to comment
mattryan Posted January 19 Author Share Posted January 19 Thanks Wes yes that seems to be the easiest route to take at this point. Quote Link to comment
The Hamma Posted February 3 Share Posted February 3 I have been able to recreate this issue with files that contain references. Either the plan is referenced or the styles are referenced. Also causes havoc with the undo command. Quote Link to comment
