sforrest Posted January 18, 2022 Share Posted January 18, 2022 Just upgraded from VW 2018 to VW2021 (old habits die hard...) Can someone please explain how to create a reference marker with an arrow as in the attached image? So simple in past VW versions.... Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted January 19, 2022 Vectorworks, Inc Employee Share Posted January 19, 2022 Hello @sforrest, There is already a similar reference marker style called "Ref Marker - Dwg No Sht No Lrg Arrow". You can insert it in the drawing, then enter its layout and simply rotate and move the black triangle in the desired position. Another way to go would be to select the black triangle, select Rotate with Marker in its OIP and then exit the layout and rotate your reference marker so that you get the desired result. You can learn more about the new reference markers in VW 2021 here - https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FAnnotation%2FCreating_reference_markers.htm&rhsearch=reference marker&rhhlterm=reference marker&rhsyns= Best Regards, Nikolay Zhelyazkov Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted January 19, 2022 Vectorworks, Inc Employee Share Posted January 19, 2022 P.S. just got a tip from @Matt Panzer that the rotation of the arrow could be done even easier using the Arrow Angle parameter in the reference marker OIP: Quote Link to comment
