Viewport naming issue
Bertf
Hi,
I have the following issue:
When I create a 2nd viewport on sheet 1 and the checkbox "Name viewport as Dwg No./Sheet No." is checked. It receives the name "2/1".
When I then duplicate this viewport on this sheet, (just to change some visible classes for example). The name of the duplicate is 2/2 and not 3/1 as one would expect:
This gives the issue that when I create a 2nd viewport on sheet 2 with the auto naming checkbox selected that I get a naming conflict because 2/2 already exists on sheet 1...
So is it possible to fix this that duplication of a viewport changes the name according to the autonaming convention "dwg no/sheet no"?
Or even better in my opinion: Change the auto naming of a viewport to "sheet no/dwg no", then the duplicate viewport logic can remain the same.
Thanks,
Kind regards,
Bert
Edited by Bertf
1 answer to this question
