Key commands stopped working
MartinBlomberg
Hi,
I've assigned ⌘+Shift+1 to "Activate layer". All of a sudden nothing happens when I press that command.
The class gets activated when I right-click on an object and then click "Activate class", but when I use the key command it doesn't.
This also goes for a number of other commands that I try running. Why is this?
Thanks!
I'm on VW2022 and on a brand spanking new MBP M1 Max, 64GB Ram, 24 core GPU.
4 answers to this question
I edited my workspace and it kind of works for me.  If I right click on the object first to open the menu, then the keyboard shortcut works.
If you still have VW2021 installed, can you please check and see the the right click is required there or if the shortcut can be accessed when you just hover over the object?
