Construction Documents
Guest Wes Gardner
@E|FAThe details are drafted...I think what you'll find is that you end up with a hybrid environment...some stuff is modeled and then embellished in 2D other stuff might be 100% 2D...I have absolutely no problem with drafting in 2D and placing it on a sheet, add some call outs and getting it out the door - quickest means to an end...
Same with the pdf set - alot of that was drafted using the model as an underlay as you've suggested - once again, quickest means to an end...I can draft really quickly 🙂
Wes
