VW to Augment3d
Nickriba
Is it possible to import a lighting rig from Vectorworks entertainment into Augment3d with the educational version of Vectorworks. I was able to import the scenic model but I'm not sure what file to export the lights as. Any help would be much appreciated.
1 answer to this question
Late response, but yes it is possible to import the lighting rig, but you have to install the plugin from ETC into Vectorworks to do it. I have included the file link below.
As a note, each fixture has to have both an address and a channel to export, as well as be in a visible layer.
Plugin Location (as of 4/2/2022)
https://www.etcconnect.com/WorkArea/DownloadAsset.aspx?id=10737506023
download and follow Instructions in included PDF file.
