Transparent Extrude Along Lines with a solid subtraction
EAPs have no fill in Top/Plan view
As @Tom W.suggests you can select the object and AEC>Create Auto Hybrid to automatically create an object that has your 3d component and an automatically generated 2d component that can obsucre what's below.
Or you can create a 2d/3d Hybrid Symbol from the 3d EAP
How can I undo the AH? Not getting the desired results, the object turns transparent in any view except plan.
I think you need to Convert to Group (Command K) to un-auto-hybrid it so to speak.
But be interested to know why it's displaying transparent in 3D - do you have it set to display only in 2D in the OIP?
For some reason the object was located about 300' below 0'-0" level. I relocated it and looks OK now.
