We are experiencing an issue when trying to access files from your Synology NAS device. We are running VW2020 and have recently updated our workstations to Big Sur 11.6.2. A number of workstations are no longer able to open a file without getting the alert "The file is currently in a read-only state (file may be in use by another application). Do you want to open a copy of it with a new name?"
I need to find a solution. The current option is save local and then drag to file server, then rename. This is not a solution, this is simply a bandaid.
khertzog
Where do we go from here?
Kevin
1 answer to this question
