  • 1
VW 2022 Bugs (or features, or PEBCAK)
“make active class”  from right click context menu on extruded solids doesn’t work.
“Callout Preferences,” “Leader Options,” “Marker” defaults to class marker, regardless of this selection.
Changes to custom Workspaces save in the default library on the local drive, instead of the shared drive identified in “Preferences,” “User Folder.”
Is this just me, am I doing something wrong, or are others having these issues?
Thanks!
4 answers to this question
More bugs:
Hatches resizes with the "attribute mapping tool" do not print as adjusted (see attached)
Title blocks with "Lock to Page Center" selected will relocate themselves +/- 1/4" toward the center of the page, covering any drawings or text. Tugging at the title block corrects this error.
Changing a Callout Note number under "Keynote Identifier" in the OIP requires two clicks to stick, instead of one.
Yes, this happens in multiple files and is reproducible.
Hello @jason schneider,
- Could you send me a test file with steps to reproduce this issue?
Thanks,
Nikolay Zhelyazkov
