My Demolition class is a light dashed line with no fill. When I put windows in that class, in Top/Plan view, the area representing the jamb depth and the window's width (to the outside of the frame) has a solid fill that I can't seem to make go away (otherwise, the window's attributes, such as for the trim, are as expected). In Window Settings > 2D Visualization > Set Attributes By:, > "Object" is selected. And I've tried messing around with the "Visibility Classes," all to no avail.
I've just discovered that if I temporarily turn on the Fill for the Demo class, change its color, then turn it back off, the Fill of the window then uses that new color. Leading me to believe that windows use a class's fill, even when that class's fill is turned off.
Oh, just found that if the window has a sill, then the opaque fill can be made to go away. So, part of a bigger, super counter-intuitive issue that I've encountered before, where you need to have a sill in order to not have a plan representation of the "sill"... ... ... *sigh* Luckily new windows are on the horizon, yes?!?... VWIS227
willofmaine
3 answers to this question
