GVRT Posted January 4, 2022 Share Posted January 4, 2022 Hello, I've created some data tags for position labels. I've left justified the text of the label because the content is sometimes long, sometimes short. When I mirror it, I need the text to automatically right justify - is there a way to achieve this? See image attatched I currently use two data tags styles - left and right - to work around this problem, but it's very fiddly. Thanks in advance GV Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted January 4, 2022 Vectorworks, Inc Employee Share Posted January 4, 2022 Hello @GVRT, Can you share a sample file with the data tag in it? Also, which version of VW are you using? Best Regards, Nikolay Zhelyazkov Quote Link to comment
GVRT Posted January 4, 2022 Author Share Posted January 4, 2022 Of course, sample file attached. I'm using VW22 datatag sample.vwx Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted January 4, 2022 Vectorworks, Inc Employee Share Posted January 4, 2022 39 minutes ago, GVRT said: Of course, sample file attached. I'm using VW22 datatag sample.vwx 88.33 kB · 0 downloads Thanks for the sample file! Unfortunately, I do not think that there is a way to make this happen. You can turn off "Text Wrap" of the text object to get the desired result, but I guess that you want this on, so it is not getting the job done. Quote Link to comment
GVRT Posted January 5, 2022 Author Share Posted January 5, 2022 Hi Nikolay, Turning off text wrap completely works - thank you! Thanks for taking the time to have a look at it. Quote Link to comment
