BGD Posted January 4, 2022 Share Posted January 4, 2022 Hi, I'm having strange problem. No matter whatever I try, changing the hardscpae setting, changing the top component of slab, or OIP>Texture setting, the hardscape's 3D texture remains solid white. It just doesnt change. I want to change it to grey tiled sort of texture. Nor does it let me change the name of the hardscape. What am I missing here? Thanks for helping VW19 Hardscape.vwx Quote Link to comment
Benson Shaw Posted January 4, 2022 Share Posted January 4, 2022 (edited) Hi, BGD I see two things which may affect this, but I'm working in v2022, so might be misleading. For sure the dialogs are different. 1st: in class settings for the class Component-ExtFinish-Site Stone Paving, the texture is not turned on (also, this is IMO a good candidate for Use at Creation): 2nd: in hardscape component settings, the texture component is set to "Texture" rather than Class Texture: Ported the v2022 file back to v2019, but cannot check it in native form. HTH -B Hardscape v2022 v2019.vwx Edited January 4, 2022 by Benson Shaw Clarified, hopefully 3 Quote Link to comment
BGD Posted January 4, 2022 Author Share Posted January 4, 2022 That is excellent. Works now. Thank you so much. I would have never been able to fingure this out. 1 Quote Link to comment
