CEOLIGHTINGDESIGNER Posted January 3, 2022 Share Posted January 3, 2022 Ciao a tutti ho questo problema con vectorworks per quanto riguarda il cablaggio. Mi spiego meglio quando eseguo il rendering il cablaggio che ho creato invece di prendere la forma del cavo è un visore reticolato oltre al fatto che non posso modificare alcuni simboli ad esempio: quadri di distribuzione power pox ecc. Mi potete aiutare? Grazie! Saluti Matteo Illuminazione Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted January 7, 2022 Vectorworks, Inc Employee Share Posted January 7, 2022 Hi Matteo I'm afraid you will need to post in English to be able to get much help here, I tried using google translate to get a better idea about what your post is about but it it only partially translates for me. If I am understanding correctly you are having issues with the new cable tools, These threads have a lot of info about the new tools and may provide you answer Quote Link to comment
CEOLIGHTINGDESIGNER Posted April 28, 2022 Author Share Posted April 28, 2022 Hello I wanted information on the visualization of the wiring in the 3D view, as I have seen the path of the wiring in the 3d view is displayed as a pipe sol. I wanted to know if it was possible to also view the individual harnesses as pipes in the 3d view as they are currently displayed as lines. It would also be interesting if in the new vectorworks 2023 the function would be introduced to insert a socket or a plug at the end or the beginning of the wiring with automatic connection as is already possible with the fixtures, for example if the object in question is a socket or a plug or a connector is moved the length of the cable would automatically adapt and remain connected to it, the problem I have is that I cannot view the wiring in 3d but it only displays it as a line not as a pipe, for the other request if give me directions where to present it, I'll gladly do it! With best regards MATTEO Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted May 2, 2022 Vectorworks, Inc Employee Share Posted May 2, 2022 Hi Matteo Thanks for the feedback, I'll add it into our developers system. If it helps the new cable tools skill video's are now available on the Vectorworks university, https://university.vectorworks.net/ Gruße Jesse Quote Link to comment
