Jayme McColgan Posted January 3, 2022 Share Posted January 3, 2022 (edited) hey y'all, i need to go though a bunch of symbols and attach a record and fill out the fields and I'm trying to automate that... ive got a way to do it for symbols i have inserted into a drawing but i need to find a way to do it to the symbols that live in the resource browser. is there a way to attach or update a record for a symbol in the resource browser? EDIT: i kinda shifted directions half way though this... this topic is really about how to return all the lighting devices in the resource browser. Edited January 5, 2022 by Jayme McColgan Quote Link to comment
Boh Posted January 3, 2022 Share Posted January 3, 2022 You can attach a record to all the symbols in a selected RM folder via the tools menu. This will just apply the default record field data to the symbols. If you want to change the record info for these symbols from the default you need to right click on a symbol in the rm and select “attach record”. Select the record and click on the edit fields button. Quote Link to comment
Jayme McColgan Posted January 3, 2022 Author Share Posted January 3, 2022 5 hours ago, Boh said: You can attach a record to all the symbols in a selected RM folder via the tools menu. This will just apply the default record field data to the symbols. If you want to change the record info for these symbols from the default you need to right click on a symbol in the rm and select “attach record”. Select the record and click on the edit fields button. yeah... but how do i do that from a python script. Quote Link to comment
MullinRJ Posted January 3, 2022 Share Posted January 3, 2022 (edited) Quick answer: vs.ForEachObjectInList() There is a nearly perfect example in the Function Reference. Raymond Edited January 4, 2022 by MullinRJ Quote Link to comment
Jayme McColgan Posted January 4, 2022 Author Share Posted January 4, 2022 8 hours ago, MullinRJ said: Quick answer: vs.ForEashObjectInList() There is a nearly perfect example in the Function Reference. Raymond can't really seem to figure out how to do that for the items that live in the resource browser. I'm not trying to work on symbols that are placed in my drawing... Quote Link to comment
Jayme McColgan Posted January 4, 2022 Author Share Posted January 4, 2022 so heres a slightly different question... how do i loop through all symbols in the resource browser and build a list if a symbol has a certain record attached to it. in this case i need to build a choice list for a dropdown in a dialog box.= based off symbols that have a specific record attached to it. Quote Link to comment
MullinRJ Posted January 4, 2022 Share Posted January 4, 2022 26 minutes ago, Jayme McColgan said: can't really seem to figure out how to do that for the items that live in the resource browser. I'm not trying to work on symbols that are placed in my drawing... Which items? Different items reside in different lists. The SymbolDefs are in their own list. The Resource Manager presents items from multiple lists, making it look like they are all under one roof, but they are not. Raymond Quote Link to comment
Jayme McColgan Posted January 4, 2022 Author Share Posted January 4, 2022 yeah i got that. ideally i want to go though everything in the resource browser. I'm starting to make some head room with vs.FSymDef() and others that go along with it. i understand i will have to deal with each type of symdef and loop though folders within folders as they pop up to get symbols within. ill pick this back up tomorrow. going to sleep Quote Link to comment
MullinRJ Posted January 4, 2022 Share Posted January 4, 2022 1 hour ago, Jayme McColgan said: so heres a slightly different question... how do i loop through all symbols in the resource browser and build a list if a symbol has a certain record attached to it. in this case i need to build a choice list for a dropdown in a dialog box.= based off symbols that have a specific record attached to it. Here's a very useful script you'll have a hard time ferreting out of the Script Documentation. Sorry, it's in Pascal, so you'll have to Pythonize it. Like you, it's bed time. I assume you can build your list from this. Good luck, good night. PROCEDURE xxx; { Show the name of each symbol definition that has the record name 'Bob' attached to it. } CONST RecName = 'Bob'; function DoIt2It(H :Handle) :Boolean; Begin if (Eval(H, (R IN [RecName])) = 1) then AlrtDialog(GetName(H)); { show Symbol Name } End; { DoIt2It } BEGIN ForEachObjectInList(DoIt2It, 0, 0, FSymDef); END; Run(xxx); Raymond Quote Link to comment
Jayme McColgan Posted January 5, 2022 Author Share Posted January 5, 2022 here my version, might be able to be cleaned up some but it works for me. import vs ### init List of all lights all_lights = [] ### init List of lights to ignore cur_lights = ["Viper", "Leko Body", "ETC Source 4 Body"] ### 121 = Lighting Devices ### 92 = Symbol Folders ### Loop though everything in a current symbol folder def start1(cur_handle): first_sym = vs.FInSymDef(cur_handle) for i in range(20): if first_sym.type == 16: add_Symbol(first_sym) first_sym = vs.NextSymDef(first_sym) ### Add lighting device to list def add_Symbol(current): hasRecord = vs.Eval(current,("R IN ['Light Info Record']")) if hasRecord: if vs.GetName(current) not in cur_lights: all_lights.append(vs.GetName(current)) cur_lights.append(vs.GetName(current)) return None ### main loop def start(): #path = vs.GetFolderPath(23) + "MIG Symbols.vwx" #symfold_list, num_list = vs.BuildResourceListN(92, path) symfold_list, num_list = vs.BuildResourceList(92, 0, "") vs.AlrtDialog(str(num_list)) for i in range(num_list): cur_handle = vs.GetResourceFromList(symfold_list, i) start1(cur_handle) vs.AlrtDialog(str(all_lights)) return None Quote Link to comment
Jayme McColgan Posted January 5, 2022 Author Share Posted January 5, 2022 (edited) a few issues things i encountered... i encountered these in both VW2020 and VW2022 - i think vs.BuildResourceList() is broken... the code below (which is just a portion of the whole script) return the correct num_list but the symfold_list wouldn't have a handles in it. i could also be using it wrong... path = vs.GetFolderPath(23) + "MIG Symbols.vwx" symfold_list, num_list = vs.BuildResourceListN(92, path) - i tried building a list using type 121 (Lighting Instrument - Symbols) but it always returned nothing. Edited January 5, 2022 by Jayme McColgan Quote Link to comment
