Currently if you're in a 3D perspective view and want to add a RW camera that matches the current view, you must:
Activate RW Camera tool
Click once to set insertion point
Click again to set view direction
Move mouse over to OIP and click on "Match Current View" button.
Note also that steps 2 and 3 "feel" wrong because you're inserting a camera in an arbitrary spot just to get the object into the document.
What would be great is to have a separate mode button for the RW Camera tool that automatically inserts a camera that matches the current view when clicked.
Now that I think about it though, a mode button might be challenging because how would it work when in Top/Plan?
So perhaps instead it could be a new command under the View menu called "Insert Camera at Current View" which would insert a RW camera using the default RW camera settings. The command would only be available when in 3D perspective.
A command would also be great because users could assign a keyboard shortcut to it. I would certainly use this a lot when finding camera views with a Director or Production Designer.
There might also be an opportunity to add a command like this to the Visualization > Cameras palette.
Andy Broomell
VE-102615
2 answers to this question
