Menemeth Posted December 13, 2021 Share Posted December 13, 2021 So help me if im doing something wrong, as im new to using braceworks. But i inserted a simple 10' stick of truss with a 1000lb point load on it. with 2 motors supporting the span. truss weight 67 lb motors with chain weight 187lb each point load 1000lb was expecting roughly 720lb per motor with it being a 50/50 split but when i run calculations it says motors are overloaded with 1273lb per point what am i doing wrong? or is this right? braceworks test.vwx Quote Link to comment
Vectorworks, Inc Employee Scott C. Parker Posted December 13, 2021 Vectorworks, Inc Employee Share Posted December 13, 2021 I had the exact same issues when I started using BW. Change the Braceworks Preferences to "Usability" when you're comparing to hand-done math. This turns off the added safety factors. Best, Scott 2 Quote Link to comment
