Seena Hassouna Posted February 22, 2005 Share Posted February 22, 2005 So I made some classes for different types of notes. 1st flr. plan 2nd flr plan. etc. as was suggested by some of you. I seem to fine that my callouts lose the arrow at the end. Whe I check this in the PIO window, it says "solid arrow". I try to change it to another tyoe to refresh but nothing comes up. It's just a line with no marker at the end. Has anyone else had this problem? Thanks, Seena Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted February 22, 2005 Vectorworks, Inc Employee Share Posted February 22, 2005 Are you sure that the marker isn't just very small? I assume that you're drawing these callouts on design layers. What scale are the design layers set to? If they're 1:1, then the markers are just very, very small. Fix this by setting the scale of your design layers to the scale that you use most often in your floor plans. Quote Link to comment
buz Posted February 22, 2005 Share Posted February 22, 2005 Also I have found sometimes the arrow is behind something sometimes. Just bringing it forward or to front will do the trick. Quote Link to comment
