Patrick Schulze Posted December 2, 2021 Share Posted December 2, 2021 Accessory alignment in VWX 2022 seems to place base of accessory at fixture's insertion point in some instances. When this happens the Device Type also changes to "Static Accessory" Am using the same fixture library from 2021 converted to v2022. 3D orientation is fine. Attached file shows what is happening. Accessories 2021 v 2022.pdf Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted December 7, 2021 Vectorworks, Inc Employee Share Posted December 7, 2021 Any chance you can post a file Patrick? Need to check parts records etc. Quote Link to comment
Patrick Schulze Posted December 17, 2021 Author Share Posted December 17, 2021 (edited) accessory alignment VWX2022.vwx Odd that some work and some do not. In VWX 2021, they all work. There are other symbols and accessories that act in the same manner. I think it has more to do with the fixture symbol than the accessory. If you take the accessory that appears correct on the middle symbol and try to apply it to one of the others, the placement is wrong. Thanks Edited December 17, 2021 by Patrick Schulze additional info Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 5 Vectorworks, Inc Employee Share Posted January 5 Hi Patrick, I have filled a bug with your file. I could not find an explanation either. All the best Tom Quote Link to comment
hrawls Posted January 17 Share Posted January 17 Hello. I recently updated to 2022 and I am also having issues with accessories. When I place an accessory, it takes the channel number and purpose notes from the fixture that it is attached to. This sort of makes a hot mess- I can't read the fixture type under these notes. This did not happen in previous versions. Is this a bug or is there a way to turn off labels for accessories? Thank you. Quote Link to comment
mjm Posted January 18 Share Posted January 18 For the folks posting their issue here: are your fixtures being turned from Lighting Devices into Static Accessories? 1 Quote Link to comment
MattLXdesign Posted January 18 Share Posted January 18 10 hours ago, hrawls said: Hello. I recently updated to 2022 and I am also having issues with accessories. When I place an accessory, it takes the channel number and purpose notes from the fixture that it is attached to. This sort of makes a hot mess- I can't read the fixture type under these notes. This did not happen in previous versions. Is this a bug or is there a way to turn off labels for accessories? Thank you. Hi hrawls, With the accessories, there's a new section in the Object Info box for Accessories. You'll need to select the offending accessory from a drop down box there. Then in the section above is the drop down to select <none> for the label legend. The problem I'm having is copy pasting fixtures with accessories between plans for a tour I'm drawing. The object info is all filled out for the full fixture with accessory in the new plan, but only the symbol for the accessory appears on the plan???? Has anybody else has this? Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted January 18 Vectorworks, Inc Employee Share Posted January 18 Not seen that before Matt, Could you post a screen recording or copy of the file? Quote Link to comment
Patrick Schulze Posted January 31 Author Share Posted January 31 Was informed by the folks at VW that a "workaround" is to place a 2D locus on your device symbol at the point where you wish the accessory to anchor. Used to be that VWX would assume to attach at the front of the fixture. Took me about 10 minutes to update my library. Not too onerous. Quote Link to comment
Sam Jones Posted January 31 Share Posted January 31 Can you tell us how this would work with more than one accessory attaching to a single light? Color scroller, Top Hat, and Iris? 2 Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted February 1 Vectorworks, Inc Employee Share Posted February 1 You shouldn't need the workaround too much longer and symbols are unaffected. This is being worked on currently. In terms of more than one accessory this still works (Eg Scroller top-hat) The accessory tool knows that you are effectively mounting an accessory on an accessory. I will keep you updated. Quote Link to comment
Sam Jones Posted February 2 Share Posted February 2 So. ...You're saying the work around is still needed, but not much longer. While it is needed, how will it work if I want to anchor a template holder at the nose of the light but inside the symbol graphic and I want to anchor iris at the gate that is not at the insertion point. I'm assuming 2 loci won't work, because the tool won't know which locus to use for which accessory. This all being the case, I assume the workaround won't work for more than 1 errant accessory. Right? If wrong, how would that work? 2 Quote Link to comment
