gfebres@gfarch.ca Posted December 2, 2021 Share Posted December 2, 2021 After updating to 2022 SP2 many windows and doors stop "cutting" walls in shaded view (only in shaded view). I went back to SP1 and after removing and reinstalling the doors and windows, everything works OK. In a version of 2022 - SP2 I tried to fix the walls, checked for duplicate walls, deleted door and reinstalled door. One way of replicating the issue to change the label of a door; the wall stoped working. I am attaching several scree shots with 2022 - SP2 and one with 2022-SP1. I also tried opening the file (in 2022- SP2) after fixing it with 2022- SP1 and it displays properly in 2022-SP2. I can not update to SP2 in my main computer (iMac 27 inch 2017), until this issue is resolved, do not want to have to rework files again. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted December 2, 2021 Vectorworks, Inc Employee Share Posted December 2, 2021 Can you send me the Vectorworks file privately so I can have a look? Quote Link to comment
zeno Posted December 2, 2021 Share Posted December 2, 2021 3 hours ago, gfebres@gfarch.ca said: After updating to 2022 SP2 many windows and doors stop "cutting" walls in shaded view (only in shaded view). I went back to SP1 and after removing and reinstalling the doors and windows, everything works OK. In a version of 2022 - SP2 I tried to fix the walls, checked for duplicate walls, deleted door and reinstalled door. One way of replicating the issue to change the label of a door; the wall stoped working. I am attaching several scree shots with 2022 - SP2 and one with 2022-SP1. I also tried opening the file (in 2022- SP2) after fixing it with 2022- SP1 and it displays properly in 2022-SP2. I can not update to SP2 in my main computer (iMac 27 inch 2017), until this issue is resolved, do not want to have to rework files again. I had the same issue. Try to remove and reinsert the doors and windows, let me know if it works Quote Link to comment
gfebres@gfarch.ca Posted December 6, 2021 Author Share Posted December 6, 2021 Thanks Zeno, that was the first solution I tried, also verified if there where any double walls. The only way I could fix it was to go back to SP-1 and then replacing windows and doors worked. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted December 6, 2021 Vectorworks, Inc Employee Share Posted December 6, 2021 On 12/2/2021 at 3:24 PM, zeno said: On 12/2/2021 at 12:14 PM, gfebres@gfarch.ca said: After updating to 2022 SP2 many windows and doors stop "cutting" walls in shaded view (only in shaded view). I went back to SP1 and after removing and reinstalling the doors and windows, everything works OK. In a version of 2022 - SP2 I tried to fix the walls, checked for duplicate walls, deleted door and reinstalled door. One way of replicating the issue to change the label of a door; the wall stoped working. I am attaching several scree shots with 2022 - SP2 and one with 2022-SP1. I also tried opening the file (in 2022- SP2) after fixing it with 2022- SP1 and it displays properly in 2022-SP2. I can not update to SP2 in my main computer (iMac 27 inch 2017), until this issue is resolved, do not want to have to rework files again. Expand I had the same issue. Try to remove and reinsert the doors and windows, let me know if it works The Bug: I just took a look at the file and will enter a bug so the engineers can have a look. Some questions: It looks like this file was originally created in VW 2018? Does that sound correct to you? If so, do you know if it was saved in any other versions between 2018 and 2022? Do you have any idea what VW version the affected walls were last edited (or created)? Actually, if they were last edited in a version before VW 2022 and you have a version of that file before converting it, it would be helpful for us to look at. The Fix (for now): If the issue happens again, I think the easiest fix is to select any of the affected walls and move them (with the Move command) by 0, 0. This triggers them to reset properly. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted December 6, 2021 Vectorworks, Inc Employee Share Posted December 6, 2021 @gfebres@gfarch.ca, @zeno, If you can create a reproducible case of this where the wall hole shows and then goes missing, please let me know. While I see the problem in the file, I cannot make the problem happen. Thanks! 1 Quote Link to comment
zeno Posted December 6, 2021 Share Posted December 6, 2021 2 minutes ago, Matt Panzer said: @gfebres@gfarch.ca, @zeno, If you can create a reproducible case of this where the wall hole shows and then goes missing, please let me know. While I see the problem in the file, I cannot make the problem happen. Thanks! On my files I resolved after the sp2 b2or3 but yes, I'll let you know 1 Quote Link to comment
gfebres@gfarch.ca Posted December 6, 2021 Author Share Posted December 6, 2021 The file was created in VW 2022 I did create new walls outside of the model, created new windows and doors and then moved the new wall into the model. That temporarily fixed the problem, but as soon as I changed the label of one door, the problem came back and actually extended to other walls and windows. At that time I went back to VW2022- SP1 (still in the iMac), fixed the file and continues the project without updating VW 2022 to SP2. Quote Link to comment
gfebres@gfarch.ca Posted December 6, 2021 Author Share Posted December 6, 2021 The file was created in VW 2022 I did create new walls outside of the model, created new windows and doors and then moved the new wall into the model. That temporarily fixed the problem, but as soon as I changed the label of one door, the problem came back and actually extended to other walls and windows. At that time I went back to VW2022- SP1 (still in the iMac), fixed the file and continues the project without updating VW 2022 to SP2. I use templates that mat have been created on a pervious version of VW, but I started this project on VW2022. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted December 7, 2021 Vectorworks, Inc Employee Share Posted December 7, 2021 OK, thanks for the description of what you did. Unfortunately, I still have not been able to reproduce the issue in the file that shows the wall holes. We have the file that shows the problem (which is good). However, if we can reproduce the problem, we can figure out how it got into that state and prevent it from happening. Quote Link to comment
