tumtum Posted December 1, 2021 Share Posted December 1, 2021 Hi guys, I'm trying to place this truss vertical but when is try to place it with the auto connect it only snaps horizontal. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted December 2, 2021 Vectorworks, Inc Employee Share Posted December 2, 2021 What version of Spotlight are you using? if you are using 2021 please specify the truss symbols being used and the the build number of Spotlight (found in the help menu in the about submenu). If you are using 2022 it is most likely the magnets in the truss corner are not correctly set up. There is an issue with some of our default truss libraries and the new magnets, that the content team are in the process of fixing. As soon as they are done the libraries will be updated. Until the default libraries are fixed you can edit the magnets yourself, In the resource manager right click on the corner symbol and select edit 3D Component in the context menu next group select the truss magnets (you may need to turn on the Rigging-Truss-Magnet class if they are not visible) and in the OIP change the 'Allow Extra Roll Angle' drop-down to 90°, 180°, 270°. exit the edit symbol interface and save the edited truss symbol into your user or workgroup folder so you can use in future projects Let me know if this fixes the issue, if not I'll need the same info as above so that I can follow up and create a bug report. Quote Link to comment
raouls Posted December 2, 2021 Share Posted December 2, 2021 @jcogdell please could you confirm which truss libraries are being fixed. This issue sounds similar to my recent posting about issues with Prolyte H30V in 2022, I also tried Milos M290 Q, same issue. The only solution I found was to revert back to 2021. Quote Link to comment
tumtum Posted December 2, 2021 Author Share Posted December 2, 2021 (edited) Hi @jcogdell,thanks for the reply. Im using the 2022 version and the FD34 truss type. Edited December 2, 2021 by tumtum Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted December 2, 2021 Vectorworks, Inc Employee Share Posted December 2, 2021 @raoulsI've just spoken with the content team and at this point the majority of the default libraries are having issues with the magnet configuration. They are working to fix the libraries (all the service select libraries are already done) but it will take time, as there are around 5500 symbols to go through. The plan is to release fixed libraries with each service pack update. At this point the work around of editing the magnets in the library symbols is the only fix I am aware of. The only good thing about this workaround is that it only needs to be done once for each symbol, as the edited symbol can be saved for future use. Quote Link to comment
