3d Text not extruding - self intersecting geometry
FlairStudio
This might have been discussed already, I just can't extrude the polilines from the text I wish to turn into 3d, probably the font I have to use once transformed into polylines has intersecting geometry. Is there a workaround other than having to trace each indivdual letter?
Also, is there a simple way to show 2d text in the 3d model within the design layer (I.e. on the walls)?
Thank you
Federico
Edited by FlairStudio
4 answers to this question
Thank you
Federico
I would try extruding each letter separately or in small groups to see if I could find the problem geometry. Fixing the geometry is the most foolproof option.
You could also run the Simplify Polys command to see if it deletes any coincident points.
Kevin
