domer1322 Posted November 26, 2021 Share Posted November 26, 2021 can anyone help with this issue: I have multiple objects, lines, symbols, etc on one layer and I have many of the identical objects on another layer. However the same objects/lines/symbols are not on both layers. Is there a way to merge the two layers into one layer and make sure that all the objects/lines/symbols are present, but that none of them are duplicated ? Quote Link to comment
Tom W. Posted November 26, 2021 Share Posted November 26, 2021 If you were to select all the objects on one layer then assign them to the other layer, then run Purge, would it get rid of all the coincident objects? 1 Quote Link to comment
domer1322 Posted November 26, 2021 Author Share Posted November 26, 2021 No ..... on my old version of VW 2015, the purge command does not have the option to purge coincident or duplicate copies. Any other suggestions ? Quote Link to comment
Benson Shaw Posted November 26, 2021 Share Posted November 26, 2021 Oooh kayy? this might work if you are patient?? : For safety, make a duplicate of layer A (call it A.1) and work with this new layer. Or port these two layers to a new blank file and work with them there. Draw a big rectangle surrounding all objects in A.1. Select all and Group. Set Layer Vis to A.1=visible, B= gray. Hide all other layers. Select the group and offset it by a small known amount, eg x=1,y=1, enough to reveal the gray objects in Layer B Edit the group with Show other Objects pref enabled. Wherever any Layer B gray object is visible, delete the corresponding object in A.1. Repeat until no replicants are visible. Blink Test: Rapidly and repeatedly toggle the quick Pref for Show other Objects to test whether replicants are present. Exit the group. Offset the group to original position, eg x=-1, y=-1. Move the group to Layer B. Final tests: Move the group Front/Back (or Delete/Undo) a few times to verify optically that the objects are unique. Ungroup. Delete the rectangle. Rename the original Layer A and archive. Or delete Layer A. If desired, rename Layer A.1 to A. -B Quote Link to comment
