Poot Posted November 26, 2021 Share Posted November 26, 2021 Hi Everyone, I am just wondering if there is some secret trick I am missing to create sections like the one below, without having to trace a white polygon in the sheet layer? Most often when drawing large/non-detail principle sections it is not necessary to show the construction below-grade. I understand how to control this with layers and classes within landscape areas, but there is always extra geometry of various thickness that I remains. Using just the site model line means seeing the site model in the background if it is extended. Drawing a polygon overtop is not overly complicated of a workaround, but just thought I would ask 🙂 Quote Link to comment
zoomer Posted November 26, 2021 Share Posted November 26, 2021 7 minutes ago, Poot said: without having to trace a white polygon in the sheet layer? This is what I thought to be the normal workflow. Usually the other way round, to get a "terrain" section when you won't get a solid from DTM. I hope someone else has a better idea. (As such a workaround in Annotation space will not follow the changes of the generated Section) But your Section looks very good 🙂 Quote Link to comment
Tom W. Posted November 26, 2021 Share Posted November 26, 2021 32 minutes ago, Poot said: Hi Everyone, I am just wondering if there is some secret trick I am missing to create sections like the one below, without having to trace a white polygon in the sheet layer? Most often when drawing large/non-detail principle sections it is not necessary to show the construction below-grade. I understand how to control this with layers and classes within landscape areas, but there is always extra geometry of various thickness that I remains. Using just the site model line means seeing the site model in the background if it is extended. Drawing a polygon overtop is not overly complicated of a workaround, but just thought I would ask 🙂 I've done this by stacking one VP on top of the other. So a section with the buildings, etc on behind + another section on top which is just a cut through the Site Model. 3 Quote Link to comment
Jeff Prince Posted November 26, 2021 Share Posted November 26, 2021 Perhaps this will help… lots of ways to get what you want. Quote Link to comment
Poot Posted November 27, 2021 Author Share Posted November 27, 2021 (edited) On 11/26/2021 at 11:09 AM, Tom W. said: I've done this by stacking one VP on top of the other. So a section with the buildings, etc on behind + another section on top which is just a cut through the Site Model. Nice! Would there be any way to have the site model white below grade? Edited November 27, 2021 by Poot Quote Link to comment
Popular Post Tom W. Posted November 27, 2021 Popular Post Share Posted November 27, 2021 12 minutes ago, Poot said: Would there be any way to have the site model white below grade? Absolutely! This is a different file but the same principle: the buildings are on one VP where extents beyond cut plane is enabled. Then the site model is on another VP where it is just the section cut which is displayed with the attributes controlled in the Advanced Section Properties: you can have various different classes set up in advance then just choose the one that gives you the look you want. 5 Quote Link to comment
Poot Posted November 28, 2021 Author Share Posted November 28, 2021 On 11/27/2021 at 4:54 PM, Tom W. said: Absolutely! This is a different file but the same principle: the buildings are on one VP where extents beyond cut plane is enabled. Then the site model is on another VP where it is just the section cut which is displayed with the attributes controlled in the Advanced Section Properties: you can have various different classes set up in advance then just choose the one that gives you the look you want. Very nice! It does seem like multiple/overlapping viewports is the best way to get more nuanced effects and visual control. Thanks for the good tips! 1 Quote Link to comment
hollister design Studio Posted January 7, 2022 Share Posted January 7, 2022 On 11/26/2021 at 2:09 AM, Tom W. said: + another section on top which is just a cut through the Site Model. So assuming this site model section is just slightly in front of the building? Might be a bit difficult with overly complicated/convoluted terrain? In any case this seems much better than my current overdrawn polygon (with at least a cople of redraws as I move hardscape around) solution. Quote Link to comment
