Reshape Tool and Inserts
Peter King
A useful trait of the reshape tool always used to be that if you included an inserted object inside the reshape marquee, (eg a 'wide flange' steel section) it would get moved along with the lines and other elements that were being stretched or shortened. Unfortunately this no longer seems to work! I have noticed this since about VW2020 and have up until now just put up with it, using a workaround by reshaping the lines etc first and then moving any included inserted objects manually.
I just wonder if there is a setting somewhere that inadvertently got changed that is causing this to happen. I have trawled through preferences and settings but cannot find anything. I can't seem to find any reference to this on the forum or even on a general Google search so if anyone out there has any ideas I would love to hear from them!
As an addendum I would just like to point out that any home-brewed symbols that are included in the marquee continue to be moved as before, it seems only inserted elements such as steel sections that don't get moved.
Edited by Peter King
Clarification
0 answers to this question
