hollister design Studio Posted November 24, 2021 Share Posted November 24, 2021 I would like to adjust the global Plant Tool settings. The primary reason I'm looking for this is my 2022 plant tool is defaulting on "custom spread" and "custom height" and I would rather it use the plant style numbers (I've highlighted this below). In 2021 when I click on the 'Plant Tool Preferences' button in the tool bar I get the "Advanced Plant Preferences' menu with global 'Plant Tool' options. There is also a button on the bottom left "Edit Plant Style" that open the active plant objects specific 'Plant Style' menu. In 2022 when I click on the 'Plant tool Preferences' button I get the 'Plant Preferences' menu - this menu adjust the active plant objects plant style preferences and doesn't seem to directly affect the plant tool globally. And it doesn't have an option for 'use Plant Style' for any of the size/spacing options. Comparison screen grab: As a new user I did find it confusing that clicking on the 'Plant Tool Preferences' button did not open a menu called 'Plant Tool Preferences', but instead opened a menu called 'Advanced Plant Preferences'... ...a menu that although not named 'plant tool preferences' was in-fact the 'Plant Tool's preferences. Vectorwork's baroque naming schemes now hardly cause me to shudder at all. Quote Link to comment
Jeff Prince Posted November 24, 2021 Share Posted November 24, 2021 Looks like the stylization of all objects has expanded in 2022 by the looks of your screenshot. I imagine you have to set your plant style to define the size rather than allowing “by instance” dimensions. That’s just a guess though, I’m too scared to download 2022 🙂 Quote Link to comment
hollister design Studio Posted November 24, 2021 Author Share Posted November 24, 2021 @jeff prince yes, the plant styles menu has grown and changed considerably - with, as far as I can tell, no documentation to go along with it... The problem is that with the default settings I have right now - ALL plant objects are placed at 10' spread and 15' height. Oak trees and Lavenders are placed at the exact same size! This means that every time I use the Plant Tool I have to manually choose the size and spread (and spacing). This cannot be the intention. I'm sure there is a way to set the tool to "use plant style", it's just not the way we did it in 2021. Hopefully someone that has figured this out will enlighten me! 1 Quote Link to comment
hollister design Studio Posted December 2, 2021 Author Share Posted December 2, 2021 For anyone coming looking for answers, I posted in trouble shooting and Tamsin let me know this is a 2022 SP2 issue. If you roll back to SP1.1 it should not be a problem. Should be fixed in SP3 Here's the other posting. Quote Link to comment
