  • 1
Datamanager migration IFC 2x3 -> IFC 4?
matteoluigi
8 answers to this question
I haven't tried in VW 2022 though,
maybe something changed ?
In VW 2022,
most PIOs had already IFC 2.3 and 4 Tags.
Just Stairs did not have or not export even when applying IFC 4 Tags manually.
So it was mainly about applying IFC Tags to custom geometry.
If you applied IFC 2.3 Tags, there were no IFC 4 Tags.
And if you apply any IFC 4 Tag, that meant that VW switched into IFC 4 Mode.
So you can't even read your IFC 2.3 Tags anymore.
Until you do like you would want to apply a IFC 2.3 Tag again, this will switch VW
back to IFC 2.3 again. So your IFC 2.3 Tag should still be there to read.
Switching back to attach IFC 4 Tag will let you choose that Tag from the endless
lFC Tag's list again.
Rinse and repeat ....
I hope something changed until VW 2022 .....
2 hours ago, Christiaan said:
but I had problems trying to collaborate with the IFC 4 output from VW and had to switch back to IFC 2x3.
Yes, here too.
But I thought IFC 4 would have some interesting new features, for Materials and such.
Maybe I should test IFC 4 again for compatibility and reliability.
