Chris Rogers Posted November 16, 2021 Share Posted November 16, 2021 (edited) I have text set up to automatically rotate to be readable. I presume this is controlled through Document Preferences>Adjust Flipped Text? I am attempting to put parking lot numbers on a drawing, so I want the numbers oriented to the driver of the car, not to the sheet. I only want to affect the parking lot numbers, not all of the other text in the file. Is this possible to do? I should add that rotating the text manually works in model space but it displays incorrectly in the viewport. Edited November 16, 2021 by Chris Rogers Quote Link to comment
E|FA Posted November 16, 2021 Share Posted November 16, 2021 With the text selected, change the rotation angle in the Object Info Palette. You might need to choose 179° instead of 180° to prevent auto rotation, but I didn't go in and check. Quote Link to comment
Pat Stanford Posted November 22, 2021 Share Posted November 22, 2021 If I remember correctly, the amount that will ignore Adjust Flipped Text is 0.02°. So set the rotation of things you don't want flipped to 180.02 or 179.98 (89.98 or 90.02). Actually I think it is anything greater than 0.01°, so you could probably use 0.01000001°, but you will never see the 0.02° rotation and it is much easier to keep straight. 1 Quote Link to comment
kirk Posted October 26, 2022 Share Posted October 26, 2022 i go back into the layer and adjust by .02 but it still flips Quote Link to comment
Pat Stanford Posted October 26, 2022 Share Posted October 26, 2022 Going back into the layer sounds like you are coming from a viewport. Each viewport has its own setting for Adjust Flipped Text. What exactly are you doing and what are you seeing? Quote Link to comment
