John Windswept Design Posted December 16, 2004 Share Posted December 16, 2004 How do I scale patterns and hatches. At the correct drawing scale the patterns are too small. Help? Quote Link to comment
Travis Posted December 16, 2004 Share Posted December 16, 2004 I don't know of a way to scale patterns. Hatches can be scaled from the hatch dialog. From the Attributes pallett, select Hatch from the fills menu. Then select Hatch. . . from the bottom of the middle drop-down menu. There's an option to scale one or all of the layers that make up the hatch. Hope that helps. [ 12-16-2004, 06:31 PM: Message edited by: Travis ] Quote Link to comment
propstuff Posted December 17, 2004 Share Posted December 17, 2004 You cannot scale patterns as such, but in the print dialogue there is an option to print patterns at screen res. In other words, zoom the drg till the patterns have the density you want, and then print. The downside is they can become pixelated depending on the zoom and pattern. hth, N. Quote Link to comment
cairo9 Posted December 27, 2004 Share Posted December 27, 2004 you can change the pattern also ...by going to set attribute defaults, but you can't change the scale ..it is dependent on the layer scale... Quote Link to comment
