LEAFS Posted December 3, 2004 Share Posted December 3, 2004 I have moved this from my originall thread with font problems. I am running G4, Vectorworks Arch. 11.0, Logitech Trackman wheel. Right mouse button becomes disabled after an unknown command or sequence of commands. At first I thought that it was because of a font but now that is not true because I was editing a group and that disabled the pull down on the mouse. Something is conflicting with the right mouse button or the Architect workspace. It is frustrating because you don't know when this is going to take place. Quote Link to comment
LEAFS Posted December 7, 2004 Author Share Posted December 7, 2004 I talked with the NNA Tech support this morning and there is a bug in the text feature when you go to upper case lettering. This will kick out the right button on the mouse. No timeline for when this bug may be fixed. Quote Link to comment
ionw Posted December 7, 2004 Share Posted December 7, 2004 not to pour salt in the wound, but this bug has been around version 9.x, let's just say the rush to fix this is underwhelming. Quote Link to comment
LEAFS Posted December 8, 2004 Author Share Posted December 8, 2004 Thanks for the heads up. Being a newly converted AutoCad user I am reliant on the right button to run the program. I understand that people who have used the program for a while don't use the right button that often. I hope that since this has been around for a while they will make the changes to correct this. Quote Link to comment
LEAFS Posted January 20, 2005 Author Share Posted January 20, 2005 The problem with the mouse button being disabled is the Caps Lock button. Once you enter text in upper case and you leave the caps lock on it will disable the right button but if you turn off the caps lock then it will turn that function back on. that is bizzare but glad to find a simple fix to this. So just turn off your caps lock and your okay. Quote Link to comment
