Attributes Pallete Bug - Vectorworks 2022
Hi Everyone,
I'm having problem with a bug on the new redesigned attributes pallete.
When I click on the Image Fill Settings an error message appear (image attached).
A temporary solution for this issue is to use the Attribute Mapping Tool (D).
Has anyone run into the same problem?
Iúri Chagas
1 hour ago, Tom W. said:
This has popped up a couple of times here but still not sure whether anyone at VW has acknowledged the problem yet
Good morning,
This problem has been fixed in the SP1.1 build that was released on 10/22/21, build 619242.  Please make sure that you are using the latest SP1 release.  This was a problem with the initial SP1 release that was released a few days prior.
Please let me know if you are continuing to see any problems after updating.
Best Regards,
Ian
I have talked with the representant in Portugal and he was surprised with that error...I work in windows os, He experimented in mac os, and found the same error message.
