How to merge classes.
cberg
I've trying out how to figure out how to use the modify classes and layer command to merge two classes. I have read that several others have had the same question, but the explanations didn't offer up much help. Does anybody know how to do this? It seems when I try to do this that the okay button continues to be grayed out, I don't think the classes are empty.
Appreciate any help that could be offered.
  • 17 years later...
I've found that the simplest way to "merge classes" is:
1. Delete one class
2. A prompt will come up asking what you want to do with the objects on the class that's being deleted.
3. In the drop down menu on the prompt window will be the remaining classes to choose from, choose desired class
4. The two classes are now "merged"
